Side note: I'm going to make it easy for Airazor to get out because there's clearly way too much happening all at once without giving others a chance to react before too many actions are taken place, and the Maximals need her support, and I also have no idea why the door would be jammed. Sorry if I'm missing something here, WorpeX.
NK, why did Umbra get to pull off so much at once without anyone else reacting to him, especially Tigatron? There are two other Maximals present who certainly would've stopped him for questioning despite his disguise. It's not like Tigatron was alone.
IC:
"Understood," Rhinox replied to Orcariner. Then he nodded to Tigatron who turned slightly in his seat and actiavted the shields, which had regenerated to 70%."Rhinox," "We're outside proximity range so you're clear to pull up Sentinel's shield. Rattrap and I will do our best to draw the Predacon's gunfire away from the ship."
"Shields are on-line," the white tiger confirmed, a greensih and blue aurora now surrounded the Axalon.
"This is Airazor to all maximal's. I'm stuck in the CR chamber, it wont open. Could someone come down and help?"
While Wintersong answered Airazor over their open link, Rhinox's attention was quickly detoured to Tigatron's voice."Airazor Tigatron and Rhinox should still be inside, the rest of us are out in the middle of a battle with the Preds, and unfortunately we're swamped out here to come back inside."
"Two autoguns off-line, Rhinox!" Tigatron alerted him. "With damage to the hull before the shields were activated." The broken ship shook and rattled from Terrorsaur's shots. Alarms sounded inside partnered with red lights flashing in every room and corridor.
"Primus," Rhinox cursed in frustration under his breath. "Come on, guys, take down those fliers!" he tried encouraging with positive thoughts even though no one could hear him but those nearby in the base.
Finally, something was going right! Rhinox, more than relieved to hear of Whitegrazer's return, was suddenly focused on the lift that had been triggered. Immediately he drew one of his chain guns and targeted the glass door. It shouldn't have been any Maximals in the field. Not yet. He kept a steady grip with his large weapon held out in front of him despite his still minorly injured hands, but he was positioned far away enough from the door in case of an ambush."Unit: Whitegrazer's core consciousness is back to normal parameters."
Tigatron turned around to see what was going on and why the sudden silence from his fellow Maximal.
"Dinobot...?" Confused but still suspicious, Rhinox kept his chain gun lifted as his red optics followed him. This didn't make sense, though. Dinobot never abandoned battle when he was right in the thick of it. And his voice... wasn't quite right. Who was this? The engineer's optics shifted to the monitor above Tigatron's head that was indicating the Maximal signatures outside. ...Dinobot's was still registered out there...Megatron's forces outnumber us 3 to 1!What are you still doing in here?!
Just as puzzled as Rhinox about Dinobot being there, Tigatron watched the fake Dinobot approach him before he noticed the expression on Rhinox's face.No.. this wont do..
In that moment, Rhinox had already turned and noticed someone else was still on the platform who had come up with this imposter. Slagging Predacons!
It was too late for the white cat, however. Just as "Dinobot" forced his hand over his mouth, Tigatron tried to jump up out of his seat but his body suddenly felt stiff after a sharp pain into his back and then went limp.
Instead of taking his chances with "Dinobot" and likely hitting Tigatron especially since he might use his own Maximal friend against him as a shield, Rhinox opened fire at Cecaelia and then immediately ducked for cover behind the large, round center console, lifting it off of the floor on an angle to better cover himself. He didn't know what this master-of-disguise did to the white tiger, and what his weapons were, but both of these Predacons just picked the wrong fight. He sent a quick text to Whitegrazer, @Whitegrazer: WARNING: Two Predacon intruders in command center. Requesting immediate back-up. Hopefully she could recover quickly from her little deep-space exploration.It would seem if we can not defeat his forces.. we must become them!
Reaching over to the console behind him, Rhinox pressed a button that dropped a device from the ceiling just above "Dinobot's" head. The same trick had worked before on tresspassing Predacons and knocked them for a loop, but that didn't mean it would work again. He wanted to activate Sentinel but feared that the fake would use Tigatron's body to protect himself. Now was a chance for him to wait and see what this guy and Cecaelia were capable of with their weapons, strategy and intelligence.
"Come on, come on, come on!" Rattrap said impatiently while he watched his much larger comrade punch a hole in the rock and lay the battery inside. Hopping on to the controls of the gun turret, the acting Maximal leader activated the weapon and quickly got himself familiar with the controls. Although his line of vision was scured by the armor plating which in-turn protect him very well for the time being, he tapped into Orcariner's Beacon tech and located a particular flier that was really wreaking havoc on the base. "Ol' needle nose got a make-over, too, eh? Still pretty ugly. Maybe I can help him with a few touch-ups," Rattrap snickered to himself outloud. Rotating the turret gun slightly, he targeted Terrorsaur."We need to move fast. Really fast."
"Ain't that what I do best, Big O?" he asked him rhetorically. Just as the TransMetal orca took off, impressed by his ability of flight now, Rattrap unleashed a barrage of firepower in Terrorsaur's direction."Let's hope you and I can distract them long enough for the others to finish setting up shop. We're going to have to hit the Preds hard and loud."
(( OOC: EDIT: OKay, una deleted her post with Whitegrazer and I don't have time edit everything I just wrote, so... una, put Whitegrazer's part back up! Please. ))
